1 - 4 of 4 Posts
Go with the basics............
Wash out fueltank,,replace fuellines /filter,,clean carb,,make sure the carbs arent loose,,replace sparkplugs....If theyre two stroker model bikess you need a 40:1 fuel ratio of premix oil to 93 octane fuel...
If it gives problems you may neeed to reset the carb float ,,change the carb/intake gaskets or flip/replace the reeds if equipped
If theyre cags and have petcocks atop the carb,,,Do a search for petcock mod........Good Luck...
1 - 4 of 4 Posts
