Hello,
My name is jason
I was lucky yesterday in a couple respects. I went to our local recycle center and bought a pocket bike for $25. I was also lucky to find you guys to help with this obvious basket case. As far as i have learned it is a blata replica with a mt-a4 engine. It is missing its pull start, and the little tangs on the flywheel that pull start claw grab on to. The front dual brake lever base is broken. Lastly the water pump isn't turning the o ring belt thingy is there but the water pump pulley is siezed.
I have found all parts online. but would like to gett a hold of those little tags and springs if there are any . rather than buy a whole flywheel asm. to access the water pump bearings does one need to split the cases? I would check but it is 0 degrees outside don't feel like looking today.
Lastly if anyone has these parts used i would be interested in buying them.
Thank you
Jason
My name is jason
Thank you
Jason
