B1 Origami rep 39cc aircooled or watercooled engine.The real deal is made by Blata
If it were real it would say Blata all over the body,, engine and frame plus you wouldnt get it for $150 because real B1 Origamis cost over $3000 brand new...............The reps are only $600.00...........how could you tell if its a rep or a real blata?
Like Matt said they can be upgraded to be just like the real deal...........:thumbsup:oh alright thanks cam. are the reps still good? are they worth upgrading?
is it expensive t do that and what parts would you have to change?Like Matt said they can be upgraded to be just like the real deal...........:thumbsup:
The two front discs is an upgrade.Hello mate, my first post and thought I'd start here... Same bikes as I just picked up but mine was a lot cheaper... The guy just wanted rid of it. Only thing that concerns me... Yours should have 2 front disc brakes... Or have you taken it off?
Cheers, Dan.
Thanks for that info! Obvious unsure if what's an upgrade or not. Mine came with twin discs so thought it was standard!The two front discs is an upgrade.
Thanks for the info on that!Your right it is an upgrade, early years one disc, later years two. The new C1 forks I got cost $1 more for the 2 brake bottoms, you can just buy the alum bottom piece w/ caliper mounts for the other side, but then you need a double cable holder, and the caliper I can't find. The new forks I put on my A2 framed 40cc Polini Cag.
