did you tighten that screw close to where the gas is leaking?
The video is sort of long, did you watch it? I clearly showed that the screw on the bottom of the bowl ABSOLUTELY CANNOT BE TIGHTENED!did you tighten that screw close to where the gas is leaking?
It took me maybe less than 5 minutes to kick start the bike. I might be interested in buying an aftermarket card. But I want to exhaust all other possible ways first before I go out my way to buy an aftermarket Carb. Any particular ones I should look for?no i didnt watch you try to kick start the bike for 10 mins... id just buy an aftermarket carb
I thought I would help you all out by making a video, sometimes im not very descriptive but the video will always show the truth!i didnt watch it either but for sure your carb is acting up, thats why its hard to start
i feel like the float isnt rising up and shutting the gas flow off, like its stuck down, its also possible that an air vent is blocked too
you can test the carb (messy)
take the carb off the bike, take the bowl off the carb, hook gas to the carb, it should start to flood out, lift the float with your finger gently and the flow should stop, if it does then that part is working right and the float is getting hung up
Thank you very much sir for taking the time to view my video to properly diagnose whats going on. Extending a hand goes a long way and I appreciate it! I also want to thank BlitzMInc too for helping a fella out!Ok ya I sat through that long *** vid the smoking I saw was not a exhaust leak it was burning gas off the pipe or grease from you hands that is not a problem at all it will all eventually burn off
As for the carb problem it def looks like it is overflowing I would do the test that blitz said take off the carb and take the bowl off and hook a gas line to the carb let it pour out and then push the float up and the gas should stop if it does than the float is not set right the 10 deg float level is to allow enough fuel into the bowl you can set the carb on a level surface and use a clinometer app or degree level app on your I phone I pod or smartphone and check to see if you have the correct level
