Leakage Between Cylinder Head & Cylinder Block
1283 Views 1 Reply 2 Participants Last post by  CAM2
Hey guys,
i have a leakage between the cylinder head and the cylinder block. The engine has been taken apart. The gasket in between the two looks fine. What else may be causing this leakage?. I dont want to simply replace the gasket and then see it leaking again. Someone else mentioned it might be the o ring seals. Don't really know how they look or where about their located. Any suggestions guys, really want to finish this job. its a x7 110cc pocket bike.
thanks again
1 - 2 of 2 Posts
When it comes to these small engines you should of used a tack sealer and thoroughly degrease the paper gasket before applying the tack spray sealer at the least..........
You should really put new gaskets...Good Luck
1 - 2 of 2 Posts
