Looking for exhaust pipe for my 22-ish CC. same engine as a go ped G23LH 2 stroke
4949 Views 7 Replies 3 Participants Last post by  CAM2
I am wanting to buy an exhaust pipe that will fit on my bike
Most of the go ped pipes go above the engine, and I wouldn't care if it would fit
but as you can see, there is limited room above the engine
I would REALLY like one that goes along the side of the frame like a real chopper
1 - 8 of 8 Posts
Nice looking build...Why a 23cc engine...Keeping it streetlegal as a moped?........One thing Id definately get rid of is that non-adjustable carb and get a Walbro WT603 hp pumper carb to replace it...... Keep up the good work........:thumbsup:
How wide are the exhaust bolts, the 49cc on that bike uses this exhaust, it's upsidedown on my scooter. I did not know what it was when I bought it.
Here are the photos.
First of all, these are not street legal at all. Even under 50cc. The rear brake is bad. I plan to get a front disc someday. Then I will beef up the engine.
Second, why do you suggest a HP carb?
I figured out that the engine is G43L. It uses the same exhaust and intake as the G23LH and other goped motors (such as G230RC)
That pipe is for a goped. Not what I am trying to do.
I have found a guy near my house who will hook me up with some welding for cheap if I bring the parts in.
You use to be able to buy chrome motorcycle glass packs w/ a slash end pipe. You need a pipe to go over the engine, start w/ a U pipe, and maybe alittle straight pipe, and have the guy weld up something thats fits. Once you get the joints in the right position, draw a line on both side to line them up for welding, tack it together, put it up to the bike. You might build an exspansion chamber inbetween.
In some states they are and can be registered as long as they arent larger than 30cc's or go faster than 20-25mph.......
The carb thats on there is a WYJ series carb...They dont deliver too good of performance and are harder to tune than a WT series pumper carb like a WT603 WT813
http://www.ebay.com/itm/CHROME-EXHA...Parts_Accessories&hash=item3f1eeddfdf&vxp=mtr
You need one of these with a j-bend welded onto it and a flange
1 - 8 of 8 Posts
