I have a modded big bore 49cc Giovanni brand mini pocket bike and am looking for a replacement rear sprocket, if not a whole gearing kit. I guess this bike could be considered a cag? It was advertised as a 47cc but found out it was actually 37cc before i beefed it up.
The rear sprocket that is on there now I beleive is the stock one. It is a 54 tooth. The pinion gear is a 6 tooth.
The rear sprocket is bent (not sure how but the bike has ben sitting for years so something probably hit it) I have looked all over for this 54 tooth sprocket and cant find anything. All the sprockets list the type of chain the bike uses but I cannot remember what is on mine. I do know that my chain was very hard to find years ago when I broke it. It was a very oddball size.
I am using the stock pinion clutch drum/bell and I would like to keep it so I don't have to spend money buying an aftermarket one wiht changeable pinions. I would just like to keep this 6 tooth pinion thats on it.
My sprocket looks like this one in appearance, but of course the measurements and tooth count are different in the picture: http://www.google.com/imgres?um=1&h...39&start=89&ndsp=34&ved=1t:429,r:89,s:0,i:360
What chain sizes and sprockets will work with the stock 6 tooth pinion gear?
m trying to get this bike going because I am giving it to a friend for his kid. This bike had A LOT of top end with this gearing. We clocked it one time at over 55mph+
I just tried to measure my chain. I think I have an 05T. So I need a rear sprocket that will fit that size chain and can still use the 6 tooth pinion. The mounting hole in the center of the sprocket is about 1 1/8" across and the bolt mounting holes are about 1 1/2" center to center away form each other. The entire sprocket measure around 5.5" across.
