1 - 11 of 11 Posts
Dose anyone know we’re i can get a new steering stem and handlebars for my 43cc super razor back G scooter? The quick drop handlebar slip coupling is very loose and so are the handle bars.
Yea when you click on it the steering stem nothing happens. pretty sure that means they don’t have in stock
Mine was the foldable kind if yours is telescopic then I really don't know how to help you because I have never seen one before
Mine is fold down also. Did you remove the outside sleeve that slide over the folding joint?
That's way different than the one I have you might be able to cut a slot I'm both sides of the sleeve and use hose clamps
Mine is foldable too, My handle bars used to turn back and forth until I tightened the center bolt with wedge that goes into the frame. You might try to shim w/ alum strips cut out of a coke can, I use them to shim a loose exhaust connection also.
1 - 11 of 11 Posts
