So Im riding my pocket quad this morning, everything was running smooth, have a new clutch and just put in a moded flywheel, when it suddenly chokes out. I check the gas tank, still more than halfway full, so I give it a crank... and another, and another. I let it cool down for about an hour and gave it another try. Still no dice. I then notice that the engine compression doesent feel right, when I pull the starter it does not give it's usual resistance.
I sat down and thought about it for a few minutes and concluded that either my piston rings need changing or my reed block needs to be checked. So I take the cylinder out, carefully inspect the piston, piston rings, wrist pin, etc. As far as I can tell the piston rings are fine, and the piston itself has very little wear on it, aside from a few scratches ontop from when I was doing my Squish adjustment. I then removed the carb and reed block. the reed block is fine.
Does anyone know what else could be the cause of this loss of compression?
