1 - 20 of 57 Posts
Hi all. Trying to get some of this rats nest, errrr I mean wiring figured out. I have the headlight working and some lights come on in the speedo. My current question is the back blinkers. I have 5 wires. The brown appears to be ground and goes to both lights. The yellow on one side and orange on the other I think are the positives. The blue and green go to the middle light. Is the middle light a brake light?
Having a Digital Multimeter is the perfect tool for this job as you can trace power and do continuity tests to verify which wires have power and which have a ground point.....
Running light with brakelight together has a two filament bulb with 3 wires...If yours is only 2 wire its gonna be a running light only....
Green to green...
Blue to blue
Red to orange
yellow to brown
brown to black
Thanks Cam. Although not great at it I did use a meter. For instance on the left blinker and using wires brown to black and yellow to blue there was no voltage. With the blinker on I get voltage.
The back light has only two wires (green and blue). Do either of these get connected to the black ground?
Usually the green wire is the ground...…..
Look at meter #1 in the pics I supplied...That's continuity test mode setting...
Put your meter on that setting...ground the black probe to the battery and touch the green wire with the red wire...If you hear an audible beep that means you completed the circuit and that would be your ground wire...
Next check the black wire..It could be a ground wire aswell..
Check all wires to see the deal...If you get more than 2 beeps on 2 different wires you have a wiring problem...
Put the multimeter on 12v setting now.....
Turn on the left blinker..touch the red on each of the remaining wires til you get a reading .........That would be your left turn signal power..
Do the same for the right turn signal then your running light.......
Wouldn’t the brown that comes from both blinkers be the ground and be connected to the black?
Brown coming from the blinkers does logically seem to be the blinker grounds.
Take your multimeter and do a continuity test on both green and the black wire with the keyswitch off...If they both beep theyre both ground wires..If not find the two that do beep...…...They'll be your dedicated and seperated grounds...
Usually you want to separate the blinker grounds fron the running light to prevent feedback which would cause the taillight and the headlight to pulse as the blinker lights blink as after all youre dealing with a floating ground wiring system..
This is how to properly wire-in a blinkr system on a motorbike..Notice the lack of headlight and taillight...Theyre their own seperated system.
Its really easy on some bikes to totally strip everything handles and all then hook it up to a SLA battery to power it up just as it would be on the bike to test where the problems are then fix those problems with solder and shrink sleeving,,,....
On this X1 harness some member bought it from me when I converted my X1 to parkinglot racer...He paid me extra to make the harness as close to the real deal motorcycles aswell as replace all conventional bulbs with LEDS...
Laid out and fully functional with a connected battery they basically look like this in a nutshell...…..
Here's what I THINK I have!
Battery black to black wire - continuity
Battery black to brown wire - continuity
Key on - no blinker
black to green 0
black to blue 0
black to red 0
black to brown 11.88V
Right blinker on
black to green 7.68V
Left blinker on
black to blue 7.68V
Brown to all wires are a negative reading
Blinker bulbs work when connected directly to battery so i know they work. When wired to mini chopper wiring they will not light.
Bulbs are 10W bulbs - may be the problem?
Ordered new blinker relay - possibly the problem?
Key on - no blinker
black to green 0
black to blue 0
black to red 0
Right blinker on
Left blinker on
black to blue 7.68V
So the black and brown are negatives coming from the harness and what the chinese use as a ground is showing power along with one known to not be a ground.....
Thats a good thing to know and an obvious sign of a problem...
I would remove the whole harness with keyswitch/handlebar switch and untape the harness but you can try looking towards the charging port and keyswitch areas for obvious signs of trouble......
Only other thing I can think of is asking you how the keyswitch is wired....There should be two solid orange wires or two solid yellow or pink wires on one plug and a second plug with a black with white stripe along with solid green called the flameout....
The oranges go together to transfer the juice and the black /white wire with solid green wire are the killswitch wires...black/whire is pulse power,green is ground..
One orange comes from the fuse which is between the keyswitch and the battery into the other orange wire to transfer battery power to the starter solenoid and the rectifier..
Ground[green] or pulse power from the coil [black with white stripe]should never interfere or intermingle with the two solid same color power wires at the keyswitch....
ON position on the keyswitch connects the two solid power wires...Turning the key OFF disconnects power and enacts the killswitch…..
The yellow wire coming from the rectifier box should have a terminal lug and be on one terminal of the solenoid going to the generator/starter.
The negative on the battery connects to the frame and the frame should be free of paint.....The harness grounds to a lug on the engine case which is also grounded free of paint to the frame......
Discussion Starter #11
Thanks Cam.
I did wire in a new keyswitch awhile ago. I will check that and post a pic.
I'm thinking somewhere down the line this points to USER error (me)!
Thanks Cam.
The chinese are crafty...They use the same color wires both ways and create so much confusion its ridiculous...Its mostly due to importing rules....
Lost try bypassing the safety interlocks where you have to squeeze the rear brake handle to get it to e-start and they try wiring in a brakelight then they lose the key and twist all the wires together to hotwire it which shorts almost everything out in a flash..........Light bulbs included aswell as sometimes the coil.....
Im gonna look for my wiring diagrams and if you can do the intital wiring and charging system working you cab then add in on a asperate fuse the headlight/taillight then the blinkers and not be as hard or problematic as you see...........
It will be quick and youll also have firsthand knowledge on how everything works and is routed....
On this diagram you can splice the blinkers after the keyswitch and you can also use a 7.5 amp fuse to extra protect the 10 amp fused wiring before the keyswitch..
On this schematic you can also splice the gauges/handlebar switch into it after the fuse..Just omit the battery and splice it after the keyswitch aswell with another 7.5 amp fuse to extra protect that circuit..
Discussion Starter #14
I think I’m close, most everything appears to work. If I’m getting only around 8v to my blinker bulbs and my blinker bulbs are 10v do I have the wrong bulbs?
Your bulbs are 12volts 5 and 10 watts......Look at the blinker beepie box
Try bypassing the beepie box by unhooking the beepie box and hooking both wires together then measuring voltage again...The bulbs will be solidly lit.
If the voltage increases the beepie box is the draw..a 2 pole regular duty GM flasher ballast from an early model 80's car will work...
If it doesnt correct its most likely the handlebarswitch internal switch thongs..Theyre made of tin.......They can be disassembled and cleaned up..just be careful of the lil spring...……...
Discussion Starter #17
I have a new blinker relay coming in Friday. I suspect that might be at the very least part of the problem.
Cam, checked your profile you have some collection there!!
Thanks....Theyre a labor of loving what makes me happy being able to make them better than they was before or create something new or different..
One day ill add another album.Theres a few more....Maybe a lil later on...LOL
Discussion Starter #19
Made some progress today. Put in a new blinker relay and still couldn't get blinkers to work. I then bypassed the wiring to the back of the bike and wired directly to the blinker bulb itself and it worked! Looks like I have some bad wiring to the back that I need to replace.
My problem now is that in addition to the back blinkers I have a bulb in the middle that I am assuming is a brake light that I can't get to work. There are two wires coming from this middle light, a blue and a green. This is what I know so far.
Red from the harness (along with the black) gives me 12v when the brake is applied. The Yellow from the harness seems to be 12v when the key is turned on.
So basically I have two extra wires from the back lights wiring harness. A red and a yellow and two wires coming from the light, a blue and a green.
Discussion Starter #20
After thinking about it I just realized that I would have to have a third wire (ground) going to the brake/tail light. I must be missing it or it came off. Back to the drawing board!
Time to invest in some new back lights with the harness.
1 - 20 of 57 Posts
