I know it’s 2 stroke but don’t know what brand or anything else
You will need to provide a picture for identification.
Thanks for the help.. I think it is a blata 2.5Its a half fairing cag. Look for parts for a mta1.
I'd suggest buying a 2nd bike for parts
I will look at forks and see but it says blata on foot pegs I’m tryin to find a pull rope assembly I ordered one but it was wrong.. and aga thanks for the suggestion guysDefinitely looks like a blata 2.5. But check the triple tree left side and is the left fork but the front brake flat? If it is you will have to look up a Robin NB411 but be careful, some have a cog for a CAG engine and not the blata flywheel.
sounds good thanks or the infoAtvrunner2 is correct the part you need is no longer manufactured you will need to find a used pull rope assembly for the 2.5 or engine swap it with a CAG engine.
