1 - 2 of 2 Posts
hi so I have what I think is an x1 or x2 not sure but the problem I'm having has to do with the sparkplug. I replaced the spark plug and set the gap correctly but once it's in I try to pull start it and the tension is super tight and does not want to pull out with ease. any help would be appreciated thanks
That happened to me. It turned out it was the spark plug, hitting the piston head! I got a shorter plug. But also , changed the head to a different one. That solved my problem. So, first try changing to a shorter plug. And check your squish. There’s lots of threads on the subject. Good luck.
1 - 2 of 2 Posts
