1 - 3 of 3 Posts
my x18 throttel grip wont work it is like fully pulled down dont know what to do? i guss buy a new one but cant find one on ebay or amazon please help me i only trust ebay and amazon plz help!!!!!! thanks =] ;)
Git R Dun PBracer
Mught just need to tightened at the adjustment at the throttle. The small silver thing where the cable goes into the throttle. You can adjust it from there.
PBP SENIOR M!LKER
Maybe the throttle slide didnt go in correctly and is stuck open?! Id, Start at the Throttle housing, take off the cover and get the Cable end out.. See if the Handle spins. Does the Cable pull and spring back? If the handle spins and the Cable is pulling and is springing back then you should be able to put it back together correctly and it should work.. If the cable does not pull or Spring back then you have a problem with the slide and or Spring inside the carb..
Good Luck!
1 - 3 of 3 Posts
