New carb but engine keeps cutting off ?
792 Views 1 Reply 2 Participants Last post by  CAM2
I installed a new carb with a manual choke on my 110cc automatic engine .Engine starts with no problem but can't seem to keep it running unless i keep giving it throttle .played with the idle screw and still cuts off ?what to do ?
1 - 2 of 2 Posts
Try adjusting the a/f mixture screw and the c-clip on the needle...If you need to richen the a/f screw youll most likely have to bump the idle speed up aswell....Make sure the sparkplug is good and gapped between .023-.027"..If its a torch brand,,chuck it and get a NGK C7HSA
1 - 2 of 2 Posts
