Remove the carb,,totally disassemble it,,totally clean it out,,do the float restrictor mod,,replace the fuellines and fuel filter to 1/4",,drill the fueltank output to 1/4",,wash out the fueltank,,replace the sparkplug to NGK C7HSA and kickstart it......after getting it running then you need to worry about the e-starter which will most likely only need a new battery....To e-start the bike you need to pull the clutch in to disable the starter interlock...to kickstart you dont need to pull the clutch...just turn on the key and kick.............Good Luck
