21 - 40 of 40 Posts
My GRC-GP avatar bike had no body work when I got it, I put a new full body set for an MT-A2 Cag, was $ 80 then, but they are asking a lot more now. I got mine from eBay seller morethenhundreds, (MBPN, mini bike parts now, or MBPN.com. Chrisi, is the best supplier for Euro parts for us right now, I just got some parts this week, he is in Austria, my wife has friends there, lol. He is also a Racer I believe.
After a bit of tinkering with the starter and water pump, I was finally able to get the bike running. Thanks for all the help fellas!
The only thing I'm missing is the starter side foot bracket (impossible to find apparently) and the starter side bottom ferring. Any tips on where I might be able to source those?
I'll have the cover for the waterpump o ring on stock. And when you give me some measurements I will look if there will fit a footpeg support from a newer model.
Discussion Starter #23
Yeah, I have heard the GRC-RR body works with the RSR. I might try something like that. The unfortunate part is I'm only missing a bottom starter side faring. The rest of the body, I am repairing on my own.
Hey Chrisi - thanks for all the parts you have been sending me! I had the water pump pully cover and o-ring removed for the photo.
I have attached a photo of the footpeg.
A-B ~ 51mm center
B-C ~78mm center
A-C ~100mm center
Does anyone have any advice on my muffler? Looks like I'm missing the end cap. Should i look for an end-cap or a whole new muffler?
Also - anyone have a stand for sale in the US?
I would first look for a OEM body panel, its only one part. When I got my GRC GP I could have gone to Europe and bought all new body work, that's only primer, no paint. Over $700 total, more than the bike is worth, lol. A new exhaust is like $400 w/ muffler. The pipe is around 1/2" OD, there are all kinds of after market mufflers or glass pack for under $50.
RC cars & truck use a small muffler for $20 attaches w/a rubber hose to your pipe end.
Muffler is OK, looks like a older proma muffler, the endcap should be presst inside or is it completely open at the end?
Discussion Starter #26
ill take some more photos. I think it might be completely missing, the can slides off.
Discussion Starter #27
looks like the cap is completely missing. I think i will try to make my own cap with a large washer. Probably won't seal well, but its the best idea I've got.
All my euro pipes the head pipe and rear muffler is held on by springs. There are kits with springs and the U clips that get welded to the OD of the pipe for the springs to attach.
New paint. Looks like its running pretty well! A little slower than I thought - ~35mph. The engine must be tired because it seems like its getting fuel fine.
35mph is OK for a Polini 6.2 engine, it's also depends on the gearing.
Bad news there will not fit any newer footpegsupport and rsr footpegsupport is no more available.
but how fast can it get up to that 35 thats what its about its not about top speed with these parking lot racers
My Blata 2.5 did 35mph.....Not blazingly fast but it got there........Id say unless its geared abnormally high like in the 11:1-13:1 ratio range it should be hitting north of 40mph with a 6.2 case...My Polini with 4.2 case hit 40mph before mods and 8tth pinion...
Whats your squish setting?
Whats the compression number...?
When was the last time you checked the reeds?
When did you perform your last leakdown test?
What size and brand carb do you have on it..?
Pull the sparkplug and post a pic of it..Your jetting could be off too......
All these are key variables to keeping tabs on the current state of your engine to make sure its with-in specs to deliver proper performance...
i have my bike geared to go right to 35 this way it has awsome passing power 🙂
Discussion Starter #34
I think your biggest issue right now is midsouth hasn't been responding to many peoples orders recently. I would try to contact him before you order anything. For coolant hose I just use water heater hoses from amazon. The footpeg bracket is harder to come by. The Footpegs you can get at xmotorstore.com. Its an italian website but they got a bunch of stuff. Sadly they don't have the bracket you need. There is a guy in california named Ben Gacula, stockton area, that is selling fairings for an RSR on craigslist. He might have other stuff too. Hope this helps. i miss my RSR. Good frame.
Discussion Starter #36
Actually found the ad. Sent the guy an email. Thanks for the tip!
No problem man. Where are you located? I'm in the seattle area I'm alwasy looking for people to ride with if you're close by.
Discussion Starter #38
I'm about as far away as possible, in Florida. I was going to ask the dude if he would be interested in shipping.
Gross! haha nah I'm jealous you're riding season is much longer then mine. mines about... 3 weeks
Long shot - but here are the parts I've been looking for (new or used). Any points, help or tips would be appreciated!
112.232.00 - Foot pegs - straight (or even just one side)
143.230.002 - Coolant hose - radiator to cylinder
112.229.00 - Foot peg bracket (hanger) - right / RSR
110/55R6.5" (Rear Slick)
Starter side bottom ferring (GRC RSR)
Water pump rebuild kit
Possible clutch rebuild kit
Footpegs available
coolant hose for head available
footpeg bracket is out of produktion
110 pmt slick available
waterpump rep kit depends on whitch pump you run but normaly available
clutch rep kit depends on whitch clutch you run, for 2 shoe clutch available.
21 - 40 of 40 Posts
