Now I have at times made the "small" housing 1
( case 1 = with sizes for mounting of standard- and BB- Cylinder ; inner size(s) for all comment 47/49cc cranks - up to 35mm stroke )
Before mounting , you have to modify your cyl. because the channels in the case are little bigger. After that the modifiying of the cas everydody can do, how he want, re which character of the engine he prefered
PICTURE 1- attachment
( both parts are just only " quick put together - for this picture- "
- without the register pins - there is no mismatch inside, whow it looks like on the picture !!i
PICTURE 2 - attachment
All in not modified orig. condition !
Take care by modifiying the cyl. because after that the sealing area left & right becomes very small ... so do not too much
Customized ( used) cy. on the orig ( not customized) case
Case customizing ... everybody should do himself, what needed and what he want
Mounting :
Seal fluid is not needed, the area is absolut plan. I made the test before.
*... but look a little bit down: update sealing
Bearings like usual, with the in warm/ cold - method to mount
oil seals at the end of compl. mountingdann , with little 2-stroke oil - in this one its easier than in the standard case
PICTURE 3- attachment
PICTURE 4- attachment
I will test if needed an extra paper seal between, because the air is not enough between crank and case
Like ever ... Iwill/ i must test it out.
EDIT:
Should be later a paper seal between, the crank is lightly a little " strong" inside and the valve intake "needs also a few mm more " by/ for mounting !
Now I have 0,18mm - should be okay.
UPDATE 23.01.2013
I take a paper seal between the case - 0,36 mm , only for the needed air between crank and case and also automaticly a smoother mount for the valve intake and manifold
UPDATE 26.01.2013
The bottom seal / cyl. you must make new yourself as needed.
The orig. stock is to small .
Cylinder:
BB3 - version
optimal with his third channel, in combination with the case
Ignition/CDI:
stock , with. NGK Plug / silicon / 5kohm - LB 05 EMH
Spark Plug:
C8HVX
Flywheel:
the light version ( or the old ligtened version with integrated, other firing point ( different magnet position )
Starter:
Alucase with the plastic wheel ( but the old one ) and wire secure
The drill hole above must be modified from 5mm up to 6mm because in the case is a 6mm hole; the 2 other are 5mm / stock
Valve intake & Manifold:
( holesizes and sizes like : Polini / BZM/ ZPF )
Valve intake :
comes with2 x fibreglasreeds/ mono + Vvnturi
( will be customized in Polini carbon )
Rubber Intake :
fcompatible for PHBG 15 - 21 , also PHVA 14 - 17,5
By valve- & rubber intake you must open the hole sizes from orig. 5 up to 6mm , because in the case there are 6mm holes to mount
Carburator :
will be the PHBG 15
Airfilter ( " like ever " ) , the small Blata / Polini metalfilter ( K&N) ;
till now there was the best results ( on my other Blata's genuine.)
Exhaust:
will be very strong , is not really much place when mounting ... because the carb now is on the top of the engine...I tested it with the Snake and the Fatty Pipe . .... possible better to take another exhaust, a run under engine because now it's enough place between rear wheel and engine...
We will see....
Clutch:
ike ever a customized 2-arms clutch ( the same kind of clutch which worked perfect , over the years )
Transmission :
I will give him a ZPF AC bell ( 78 ) in the stock housing.
Customizing needed !!
In the moment I had only to cut off little bit of the pinion holder , because it's a little to long, so the cain runs not straight.
PICTURE 5 - attachment
PICTURE 6 - attachment
This for the moment ... other news comes soon...
Regards
Driver
( I hope, my language is not so bad to understand the discription
EDIT:
I will put the pictures again inside because the rules here in this forum don't allowed the kind and quantity of setting pictures.
Please wait ... sorry
Mounting :
EDIT:
UPDATE 23.01.2013
UPDATE 26.01.2013
Cylinder:
BB3 - version
Ignition/CDI:
Spark Plug:
C8HVX
Flywheel:
Starter:
Valve intake :
Rubber Intake :
Carburator :
will be the PHBG 15
Exhaust:
We will see....
Clutch:
Transmission :
Regards
Driver
EDIT:
