If your asking what mods to do I don't think your ready for a turbo kids wishfull thinking lot of work and lot of fab work but it can be done
If you know how to set up a turbo motor
Mods reg mod list is
22mm carb
Bigger fuel lines
Upgraded cdi
Super coil
Ngk plug
Drill out motor and mounts to 3/8 and use grd8 bolts nuts lockwasher and loctite
Then
Gusset frame in its weak points
28t rear sprocket
Better tires
Real working Speedo
Real rear shock
Mod front forks
ECT ECT
If you do the turbo setup we would all like to see that done and a vid as well
And there are a couple fuel Injected setups out there too as well you could try
22mm carb
Bigger fuel lines
Upgraded cdi
Super coil
Ngk plug
Then
28t rear sprocket
Better tires
Real working Speedo
Real rear shock
Mod front forks
ECT ECT
