^^ good answer lol .. thats what i need a little more torque to pull my brothers big *** up some of the hills in my neighborhood lol ... can your find the springs at a local harware store or do you need to special order them ? this is just gonna be a temporary fix until i order the new ones ... i was thinking of gettin the 2000rpm performance one or would that be to much for a stock motor ? thanks alot guys
Sounds like you have a 43cc and in need of more power captain...........
The stock 43cc engine can be modded to deliver 3x the power and the revs will outrev a 49cc engine aswell................
Do a compression test to see cylinder condition....If atleast 80 or above move onto next steps...................
remove engine from frame..............
remove cylinder head
remove piston from rod,,,
polish pin,pin bearing and rod journal,,
clean up piston ,,deburr piston of sharp edges on piston skirt
add 4 small windows in the piston facing the transfer ports and chamfer holes slightly...If adding a 3rd power port window piston in appropriate area
polish piston
take a dremel and add a 3rd port to the cylinder opposite the exhaust port..The 3rd power port should go as high as the transfers and be about 8-12mm's wide and be atleast 1/8" deep but going deeper is better aslong as you dont go too deep........LOL
take the dremel and widen the exhaust port at the cylinder side 1/8" wider on each side
raise the exhaust port 1/16" in the center and slope it down gradually towards the widened sides
taper the exhaust port outwards and open it up for flow
widen the transfer ports at the cylinder base and the engine case
mod the cylinder skirt on the powerport side to slipstream the velocity and mix into the transfer ports with a powerful entrance to make power...
pull the flywheel and clutch off then split the cases,,,then take a dremel and perf port the case for uninterupted velocity and flow
yamabond the head direct to the base and give 24 hours to dry
