Cam2 thanks for the tips, man I appreciate it!!! I need new sprockets and chain, any suggestions on what size front and back sprockets and what size chain? I plan on going through the entire bike. Also what about wheels do they make bigger ones so it will sit higher? Thanks again for the info!!!
Unfortunately the next biggest tire size is 8" from an X7 but they will take alot of modding to work...To get more ride height most put 1 1/2" wooden spacers under the body to raise it....
My 2011 Trophy cag snapped the seat hoop off in a crash so easy when I rebuilt it I also designed it 5 1/2" higher for a more comfortable ride.........
This is how it sat bone stock.......
Heres the carnage...The 2010/2011 steel isnt of any quality or of substantial thickness...I solid filled my frame with block-fil
This is with the rebuilt hoop and renewed height........
Heres how it sits now........
For your sprockets Id only change the 6 tooth front to a 7 until you mod it to get rid of the restrictors and to uncork the power or pull the topend and add a modded 49cc with a good perf exhaust..I have a stock 49cc head w/5 boost ports on my 2011 cag aswell as a bunch of mods..Im running 7/68 on it but I like the snappy power and quick takeoff it has......After that you could go to a 60 tooth rear......My Black Magic Cag is running 7/55.....
