1 - 6 of 6 Posts
gas isnt getting into engine some how, i put a little gas where the spark plug goes and it started for a few seconds.
its after the filter when it connects to the engine, just took the take off, filter is fine, not sure if i should start messing with that part
here are some pictures i just took
The little white knob, do you turn it so it's inline with the fuel line? I think at 90 degress like in picture 3 should be off, and turned 90 degrees so it lines up with the fuel line should be on? it's the fuel shut off valve...
1 - 6 of 6 Posts
