will do
For the project I'm going to go something along the lines of
-Race Head – (now 25/22mm) Also has bigger cooling fins.
- High performance race camshaft
- Lightweight aluminum cylinder with steel sleeve
- Oversized cooling fins on cylinder
- High compression 54mm piston with rings, pin, & clips
- Head gasket kit
- Mikuni VM26mm Performance Carb
- Intake Kit for the Race head
- Jet kit with 3 different sizes (Stock size is a #195 - Extra jets sizes of 155, 165 & 175)
- Throttle Cable
that one was a kit, after that I need an aftermarket exhaust (I'll prob just make my own and buy a can) and I'll be upgrading to oil cooled to help keep everything running smooth with the new power.
I can always upgrade suspension for the trail riding and like I said it would really be for shiggles and would be comic relief more than anything lol. It will be a while before I can do anything to it though unless I start small with a new cdi or something, just because if you do one thing you have to do the others to balance it.
