Nice I'm going to grab a old o2 sincer from work and try to make a o2 Monitor for less time spent reading plugs ...
ATV....you say you have a tread on the 4 strokes ?? If so we can move this conversation their if you want.
Mr kitty thanks Sadly the Unicase change some of my ideas but Seeing the basic design of the valve train Has given me countless ideas!!!
Somewhere I read that these engines are bad about GRENADINE Somewhere around 9 TO 10 I'm guessing that happens because this of valtrain a Is failure????
Generally they are excellent free spinning high revving engines designed for commercial brush cutters.
The four-stroke engine is actually really good for children riders under 120 LBS.
But yes the plastic cam gear is the weakness as the engine begins to heat up from the load of a heavy Rider trying to go up hills and such the valve clearances in the guides starts closing up putting a heavier load on the plastic cam gear once a tooth snaps off there goes the timing.
I have thought long and hard about modifications for these engines I just haven't come across a running one the only ones I have seen are either working and the owner is not willing to part with it or it already has the striped cam gear with bent valves and such.
The mods are really simple the cam gear is the secret in my opinion and making one on a 3D printer to advance or retard the timing then shorten the open duration to increase compression and selling different cam gears for different applications would be the fun part of tuning of course the 3D printed part would have to be molded/sand casted/CNCed made out of aluminum valve guides would be lightly honed port and polish the flow path then modify or change the carburetor to support the modifications.
Then to make good power you add a CDI to the mix.
The problem is the complexity of the four-stroke engine will make it hard for beginners to repair when things break down. And more advanced builders are demanding 2 stroke pocket bikes mini bikes with the bigger predator style engines Honda or cloned pit bike engines.
With all of that said it's still very surprising to me all these years the four-stroke has been out and there is still zero aftermarket parts for it.
