1 - 2 of 2 Posts
Stick a wrench to the magnet if the magnet on the flywheel still feels strong then it's still good.
Sometimes the coils can be bad right out of the box check that the studs the coil bolts onto are clean and free of dirt and debris and that the coil is clean so that you have good contact for ground.
Keep in mind you should have spark with no wires connected to the coil tab I have seen faulty wiring and switches produce a no spark situation
1 - 2 of 2 Posts
