1 - 6 of 6 Posts
my x3 pocket bike zenoah motor keeps overheating it just shut off and i had to walk it home :mad: but anyways i also tuned it same day for more fuel is this the reason what should i do please help me !
First check for airleaks at the carb/intake aswell as crankseals,,,,,,,,,,,,,It sounds like you may need to richen the lowspeed needle 1/4 - 1/2 turns out more and reset the highspeed needle back to factory setting of 1 1/2 turns out....The lowspeed needle is the brass slotted screw on the carb top.............
The 2-Cycle DocToR
I only had a stock carb to show with unfortunately...BUT picture 2...my thumb is on the high speed needle...
Picture 1 ...the idol/low speed needle is inside the top of the carb, my finger is pointing to where you would put your screwdriver(flathead)
1 - 6 of 6 Posts
