1 - 5 of 5 Posts
i have a pocketbike sidecar that i need a new triple tree for. the only triple trees i see are for 22 mm forks or just wrong size. my triples have 25mm tubes and about 6 3/16 on center. not one pocket bike suplier sells this size. i wouldnt mind buying a complete fork and triple set with brakes. i can use all the help thanks.
Welcome to the site.....Sidecar racers are pretty cool......Is yours complete?
All of my cags have 22mm forks except 2 and both had totally different type of fork clamps/neck tubes..
Anyways these claim to be the 25mm fork clamps you seek..It seems the 47cc DB-49 pocketdirtbikes have 25mm forktubes...
Description:
- 100% Brand New Front Fork Triple Tree Clamp
- Hole Diameter: 25mm/ 1 inch
- High class quality alloy, solid and durable
- Easy to install, no installation instructions
- Fitment: for 49cc Mini Pocket Dirt Quad Bike
https://www.amazon.com/TC-Motor-Triple-Clamps-Chinese-Stroke/dp/B07CZDRLZT
https://www.aliexpress.com/item/4000035751965.html
Thanks for the help but none of those will work. The tube size is corect but the spacing is way small.. I need 6 3/16 spacing on center those are more like 5 inches on center.
1 - 5 of 5 Posts
