1 - 3 of 3 Posts
hi my pocket bike was acting funny when i was riding it when i noticed that when i moved the throttle it sounded like it was gonna die so then it did and it started right back up when i turned the choke up but when i went to ride it the bike died(choke in down position) and its very hot after a half an hour idk if that normal also the bike is only a week old and has about 1 and 1/2 hours riding it
The rings take about 4 tankfuls of gas to seat on the cyld, should not run it wide open for along time, thats probably why its Hot, new rings creat alot of friction & heat. The poor thing is working hard. I run mine for 1/2 hour of time, with a fan if needed till I even ride it, when its new.
Sounds like you need to check the airgap between the coil and flywheel magnets aswell as reset the forks in the carb......Make sure the carb is tight too
You may want to also tackle the petcock mod and upgrade the fuellines to 1/4"
1 - 3 of 3 Posts
