Pocket bike turns on when i spray gasoline in cylinder or when its hot
115 Views 3 Replies 2 Participants Last post by  MrKitty
So i recently cleaned carburetor, air filter, spark plug, fuel filter on my pocket bike and it will only turn on and work if i spray some gasoline in cylinder hole where spark plug goes it will turn on immediately or after riding and its still hot it will turn on, but when its cold and not turn on couple of hours or day later it will not turn on, only spraying gasoline in hole or when its hot after rides, what do i need to do guys
1 - 4 of 4 Posts
Is your choke working? Sometimes the aftermarket kits will delete the choke and make them very difficult to start
Hey man its working normally, just it wont start from 2 3 pulls like i imagined, its starting normally with like 6 7 pulls, i didnt have to spray gasoline in cylinder, thanks for reply
Depending upon which carburetor you have you may have a low speed needle adjustment that is hidden...
1 - 4 of 4 Posts
