So basically it was running mint, I added some gas and 2 stroke oil. ( just did a random guess on the ratio) started er up, drove for about 10 min then it started to bog out when I tryed to accelerate. Any ideas? Could it be the fuel ratio?
I would mix a whole gallon then drain whats in the tank into the can,,mix well and then redistribute.........Would I have to drain all the gas?
Does it run fine until you open up the throttle? Sounds like the carb needs a good cleaning, improper mixture can jam up the jet with gunk. Those chinabikes usually use a monojet carb thats Easily blockedGet it running and spray Carb Cleaner slowly around the Intake manifold.. (That plastic thing you said was smashed).. If it dies, try again in the same spot.. If it dies again you have a manifold problem. Crack or Gasket..
If it stays alive, take out the reeds (under the Intake manifold) hold a light behind it see if you see any light around the reed flaps..
Could be your Clutch also.. Maybe its dead?
Did you see if the carb was tight like cam said?
fuel restriction,,,improperly set float ,,bad reeds,,bad sparkplug or misjetted carb...Yea it idles perfectly, and will run about 10km/h max but cuts out when you accelerate more
