1 - 9 of 9 Posts
just remove the bearing and bring it to your local autozone and see if they have any bearings with similar dimensions. there was a post about this before. i recommend abec 5 or 7. abec 7 isn't super super fast compared to abec 5 bearings, but it IS smoother and coasts longer than abec 5s. abec 5 is a little slower, coasts shorter, and is a bit rougher.
The bearings are not that bad..but yeah there are not top the line..think they are like 680z bearings. Which come on cheap target, walmart skateboards. What i did to mine were soak them with tri-flow silicon lube also grease the sht out of the axle with auto bearing grease.
1 - 9 of 9 Posts
