1 - 3 of 3 Posts
Is there specific batterys to each model or is it universal? I need to know what kind of battery to put into my 2004 49cc GS model. Thanks.
They are close to universal, 12v = 12v no matter what, (unless it's 12vA/C haha)
You want a 12v DC battery that is close to the same dimensions and close to the same Cranking Amps (CA / CCA) other than that it's really up to you.
SLA (Sealed Lead Acid) is the best entry level battery, and would match what was probably used "Stock" or from the Factory, but you could make an upgrade to an AGM (Absorbent Glass Mat) battery, however if you make a move to an exotic battery you will also need a compatible Charger!
There is a link floating around on here somewhere...
Alright thank you.
1 - 3 of 3 Posts
