1 - 6 of 6 Posts
I was having an issue with the cag last fall where the chain would lock up real tight at once spot through the rotation of the rear wheel. At first i though I had a bent chain, so I replaced it and same issue.
I removed the sprocket and it is not crooked or warped. Front and rear sprockets line up nicely.
I took out the axle and it seems to be off by less than 1/16th, so I'm guessing that would most likely be the issue.
I would machine a new one, but I don't have access to a lathe until the fall.
Now my question is, will the lucky 7 rear axle fit/be the same length and diameter as my cag one?
Current diameter is 10mm
Length is 230mm
Thanks for any input :)
You can buy an axle online for 10 bucks.
Being in canada, all that I have available to me are US websites offering for about 10$ with minimum 20$ shipping.
Tsunami has an axle for the Lucky 7, which is why I ask if they are compatible, I would order it right away
I am using a stock Cag rear axle on my Lucky 7, used a rear one up front, cause its longer and I put my foot pegs up front so I can kick back, its a semi chopper, going to move the rear section back 2 to 4" with 3/8 thick 6061 T6 air craft alum brackets.
1 - 6 of 6 Posts
