1 - 13 of 13 Posts
I removed all the electrical system and electric start on my X1 and now my spark is really weak and my bike is not starting. I have a kill switch which appears to be working properly its just that when it does spark it is weak, even with a new plug. Did I do something wrong? do we need the electrical system in order for these to run properly?
Hmmm, upon removing everything did you make sure not to loosen anything else up? Check all of your connections.
Is your spark plug pushed completely in?
Just wanted to say I finally got it started, sounds great too. It was idling way faster so I had to turn out the idle set screw. I removed all of the electrics and the electric starter windings also the brushes and stuff behind the starter housing. I used the keyed sleeve that was pressed into the starter windings as a spacer for the pull start catch, just pressed it out with some big sockets I had laying around. I installed my lightened clutch which I think is a great idea but I wish I would have just drilled out my own clutch, and about that 'rocket spring' I already had about a half dozen of those laying around the garage, I got them in a box of springs I bought at the hardware for $3.99, I did think about using them before but I thought they were too stiff. I guess not since they are selling them as 'rocket springs' now.
By the way, for all others interested in doing this, the old starter button now makes a real handy kill switch.
i'm currently trying to remove my electric start and i'm having some problems. i cant get the damn armerature out/off. i pulled the flywheel and got the casing to seperate but thats it. i'm stuck.
any tips or tools that i'm missing?
seadooloo;
How is the performance after removing the electric start? I would think that it would be noticably better with the engine not having to spin up all that extra mass.
Pops
Discussion Starter · #6 ·
It is running great now. I've been experimenting with different sprockets that I made at work (during lunch and after working hours of course) I'm still not completely satisfied yet but I have gotten it to 41.5 mph many times. Im going to work on the engine a little and maybe get a performance carb. I have broken my motormounts on the pullstart side of the engine though and am working on that, replacing the casing right now.
This is for big sugar...You need to take a long (at least 50mm long) 8mm bolt and turn it into the end of the winding all the way down and that will act as a puller to get the winding off of the tapered shaft. good luck if you need to pm me for more info.
SilentX1 said:
yeh i wanna know that 2. seadooloo make a suggestion plz? :)
Guys, the kill switch works by grounding the magneto. Run the SMALL wire out of your magneto (coil) to one side of a switch and ground (attach to frame) the other side. Push switch kill motor.
Its is just that easy. The original start button on the bike will double just as a kill switch.
I want to put lights on my bike so wondering are you interest to sell your completed electrical components ?
Thanks for your time
1 - 13 of 13 Posts
