Hi guys,
i need help with setting the timing for my x7 super pocket bike. I recently just replaced the head gasket. the problem is when i match the notch with the crankcase . The circle mark on the sprocket is not completely matched with the notch in the head. But is very close. So when I turn the crankcase, the circle on the sprocket lands on the opposite side of the head. but then when i turn the crankcase again towards the right it lands near the notch in the head. So overall 2 ques. how do you properly set the timing. and how do you check if its set to the right point.
thanks guys
appreciate it.
thanks guys
appreciate it.
