Someone guide me in Speeding up a Blue Electric Razor Dirt Bike
3685 Views 22 Replies 8 Participants Last post by  Atvrunner2
My 9 year old cousin has a Electric blue razor. He’s a maniac and wants it to go faster, I told him it’s possible with the right guidance. Can someone suggest parts and leave step-by-step instructions on how to upgrade it? I’d greatly appreciate it.
1 - 20 of 23 Posts
How fast does he want to go??
There is a currie 500w motor that bolts in, the back half my need to be clocked to get the wire out of any interference. But that would be the only modification. You probably gain 1 - 2 mph.
Or....
Buy a 36v controller and throttle for an MX500/MX650. Then fit a third battery in there. Easiest way is to flatten the sides of the battery tray and fit the three in sideways.
Put a fusable link (30amp fuse) in between each battery.
Thats it, better takeoff, and weight dependent, anywhere between 21 and 23mph. For pavement.
If want offroad, grass etc. Put a smaller sprocket on the motor. I believe it's 10 or 11 tooth, so drop it one which would be 9 or 10 tooth. You will lose a little top speed but have way more low-end power take you through the grass.
And the biggest batteries, if you replace all 3, is the 12v 9ah batteries.
Otherwise one battery at whatever ah the other 2 you have are.
Theres a really good kit on ebay for people new to modding razors. I'll find it and post the link here. Basically its a throttle and 36v controller, but the guy wires all the correct plugs on for you. So all you do is unplug the old controller and throttle, and plug in the new ones. Super simple. Then all you gitta do is wire in an extra battery. But depending on how old the existing batteries are, you may just want to get 3 new ones.
If you dont feel comfortable adding a battery, you can get these that are pre wired with the correct plug.
Yeah for sure the fast scooters controllers are great. Plug and Play. A friend of mine wanted me to 36 volt his mini chopper. He went with the cheaper mx500/MX650 controller/throttle. I even used all the old wiring. Just moved one of the outside wires over and added a link in between the third battery and the second battery. Here's a few pics, it's almost done, the only problem is the battery covers are about an inch and a half further apart with the extra battery in there. Need to flatten the tray to get all three batteries in.
You can actually modify the stock speed controller for free in less than an hour and gain more torque and top speed. It's called a speed limiter bridge mod if I'm not mistaken and only requires basic hand tools.
I believe I read that on here somewhere or a youtube video. Using a paperclip. But I believe the heat sinks are still small. I know Fast Scooters controllers have one extra heatsink and they're bigger. That was a video I watched of a guy who tore one apart and a stock one apart.
  • Like
Reactions: 1
By the way, That chopper project ended up with a top speed of 21mph. That was with the mx500 controller/throttle and one extra battery.
Pretty scary on that little thing. I rode it before I give it back to my buddy. And two days later he blew the rear tire. Ran over stick. So then I had to replace the rear tube. I'll good now
  • Like
Reactions: 1
Exactly! You basically create an additional pathway for the electricity and free up resistance from the limiter allowing more juice to the motor. And while the stock speed controller does have a rather small heat sink I've done this mod on 3 different speed controllers now (2 razor e300s and my mx500) and I've yet to cook any of them... one is over 6 years old lol!
  • Like
Reactions: 1
Can you take a picture of the board with the bypassed mosfet ???
  • Like
Reactions: 1
Absolutely! Give me a bit, just got the kids from school and gotta do dinner but I'll post some pics here probably in a couple hours
Here's one of my e300 speed controllers I modded. My finger is pointing to the bypass I installed. I gotta try and break the seal I made on the mx500 speed controller to show that one off lol
160219
  • Like
Reactions: 1
Yes exactly, I believe I did that on an e200 computer years ago because it wasn't working and after the mod it started to work.
Crazy stuff. I didn't do any testing afterwards other than it worked. You said you gain more torque which I know you'll feel, did you gain any mile per hour and how much? That mod and a lithium pack would probably be great for a budget build. Although that Chopper I did was only $85 to upgrade.
  • Like
Reactions: 1
Yeah i gained a little more top end along with it, i wouldnt say it qualifies for a salt flat racer or anything but it was good for a couple miles per hour at least.
  • Like
Reactions: 1
My mx500 speed controller with speed limiter bypass mod
160238
  • Like
Reactions: 1
Here's one of my e300 speed controllers I modded. My finger is pointing to the bypass I installed. I gotta try and break the seal I made on the mx500 speed controller to show that one off lol View attachment 160219
Can I use crazy. Glue since I don’t have access to a Sauter
Glue is generally non-conductive.
You can get a soldering kit from the hardware store they are very inexpensive...
1 - 20 of 23 Posts
