I just looked at the cylinder and head I don't know what I was thinking. There is about .120" there so .060" to .080" will be no problem. Thanks MikeCAM2 knows all about this stuff and so much more. Can't go wrong with his advice, he has helped me so many times. Head should not sit that low, put a 45 degree angle on the cylds shelf edge and inside the head OD where it meets that will give more drop. That's how I got the Polini 80mm clutch housing on my 39cc clone Polini W/C engine.
I will give that a try also as the engine I have coming in has a stock head $58 complete engine shipped from amazon.The Chinese are not that precise when they build those two piece head kits by parting the stock cylinder top off it's way better to use the stock cylinder and lowering it down by taking the material off of the base then raise the ports a little bit if I had easy access to a mill I would never use those two piece head kits...
I'm running a Futaba 4PV with Telemetry but the sensor it not accurate I normally don't tune with temps I go by ear mostly but I do use my temp gun when breaking in I do five 15min heat cycles then drive the car around slow each time getting a little heavier on the throttle.If you have a radio with telemetry then you can put an onboard temperature sensor and monitor your engine Temps none of my pistol style radios have Telemetry I'm not sure which ones have it and which ones don't
You don't want one.....believe me when I say they don't work on pumpgas toolbased 2 stroke engines where the mix has to pass through the crankcase past a spinning crank......Merry Christmas Everyone
Does anyone have a V 2 pedal or 4 pedal reed block setup they would be willing to part with ?
Another note to touch upon too is your engine choice....If you get rid of the reed inducted dud and build a reed inducted engine out of a piston ported engine you'll have one sikk azz powerplant....Merry Christmas Everyone
Where would I find a piston port engine with the same crankcase and clutch mounting for my RC MT?Another note to touch upon too is your engine choice....If you get rid of the reed inducted dud and build a reed inducted engine out of a piston ported engine you'll have one sikk azz powerplant....
Even just doing the full circle crank mod, blueprinting and porting,polishing and balancing to a piston ported e gine will yield way better results...
I only use piston ported engines for vehicles that will see extended use and abuse like r/c vehicles and dtand up scooters....
My highly modded 49cc piston ported engine I have in my 37lb homemade rc buggy is so powerful and insane with a 6.0v auto advancing CDI ignition system it's pumping out about 10hp easily which makes a very killer power to weight ratio enough for lightning acceleration from a dead standstill and propelling it to over 60mph on a 6:1 ratio,
The best part is having the e-starter function I can activate through the third channel on my remote ..
Good luck
One thing hes gonna learn about using a cag engine for an r/c vehicle is he better stock up on pullstarters as the ones on the cag engines get more easily caked-up with mud sand and dirt than the reed ported engines..The biggest problem is both engine mounts are totally different, would have to mod your frame mounts on the RC, and make mounts. I would just stick with what you have for now.
Plus, when you change one thing it can cause all kinds of other problems that need to be changed to work.
Mounting wont be a problem , the main mount to this truck is the 4 bolt clutch housing and the one mount on the bottom will be easy to fabricate. Do they make aluminum intakes for this piston port?One thing hes gonna learn about using a cag engine for an r/c vehicle is he better stock up on pullstarters as the ones on the cag engines get more easily caked-up with mud sand and dirt than the reed ported engines..
Another thing and food for thought is that Gravity is a splendored thing...Even inside moving engines...A single cylinder piston travels up on down a lot easier than diagonal...…Its a lot easier to balance too…….
Besides;- If he gets the Cateye engine case the engine bolts up like a cag...
If you look at the bottom of the piston ported full circle mod engine pictured below you can see the engine mounts...
The best parts about these engines is the clutch being mounted to the flywheel as the flywheel gives a lot better juggernaut effect when the clutch loads up and the crank always sideloads in the same way..No back n forth loading like a cag engine..
This insane lil powerhouse has 0.270 hp per pound...Theres 2500lb 250hp sportscars out there with less than half that power to weight ratio...…..LOL
This engine almost smashed the 64.4mph twin GP460 engines world record scooter run with a best of 62.2mph before it gave up the ghost on a single cyliner...……..LOL
For the other engines without the mounts its as simple as buying one of these....
Yes they do and like EPR said theyre very modifyable too.....Mounting wont be a problem , the main mount to this truck is the 4 bolt clutch housing and the one mount on the bottom will be easy to fabricate. Do they make aluminum intakes for this piston port?
This engine should work as long as its not wider than the reed engine
https://www.amazon.com/dp/B07QVCNF8...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Thanks again for all you help Mike
