1 - 5 of 5 Posts
sup, so i got a cateye and just got it runing good today, installed a roclet key, electric start removal. And now when i push the bike back the sprocket locks to the crank, so if the bike goes back the engine cranks the opposite way.. took the tranny off and the clutch is good, tranny is good. and if i put the tranny over the clutch without bolting it down is normal, but once i put the bolts on it locks, wether it has the chain on or off.. so yeah, i need sum help
When you removed the trans you didnt either notice the trans bolts are two different lengths or youre missing the washers..One or two screws are hitting the flywheel...
1 - 5 of 5 Posts
