1 - 10 of 10 Posts
Hello Guys,
I,am have a cag with a tunned airfilter en pipe now i,m putting my stock on it and see if that works.. My friend has a cag to a stock cag i have a filter, pipe and just changed my needle to the fift now its not going faster en its acceleration is verry verry slow.. What else can i do? I,m going to test wat the stock pipe does with this setting en then maybe i need another carbeteur? Or and other valvereed or somethinh i tink? What do you guys think of this?
1.4 springs do nothing. That is what a stock spring is. Check for air leaks on the exhaust that will hurt the performance. What pipe did you get? This may answer the question why nothing changed also.
i think stock are 1.3 the 1.4 will allow your clutch to engage at higher rpm's its better but def. check for air leaks i have 1.5's and i'm changeing to 1.4's
1.3 are stock..1.4 are not..they engage some rpms
MB_Melvin said:
They told me that this was my tunned pro performance pipe see pic:
This is my stock pipe: but then a little bit greyer..
sorry those are stock pipes..no power in those just same as stock
1 - 10 of 10 Posts
