1 - 9 of 9 Posts
bought permatex RED thread-locker from my local parts store - put it on my exhaust pipe bolts rode for about a half hour last night and the blasted bolts backed themselves out again.
is blue supposed to be better than red?
is there a thread lock that is better suited for high heated parts like exhaust?
is there a setting time that the threadlock needs to "cure" or "set" before the engine should be fired up?
:confused:
Retired Mod and Racer
i use the blue(med strenth) or the purple(low strenth), the red is to strong. They make a high temp but it is also hi strenth so i wouldnt advise using it, i use the blue on my brake caliper bolts and have had no problems from the heat when i remove em. have you tried adding lock washers to your exhaust bolts? that might work if it doesnt there is always safety wire.
what do you advise for exhaust bolts?
the same? or should i stick with the red - as like i said above, i used the red last night and the bolts backed out for the third time (first 2 times they backed out, they weren't thread locked - i know, i know that was my own fault!)
its odd that even with the red on em they backed out. 1-87PERMATEX thats the number for permatex give em a call and ask what they would recomend you use. (usually with companies if you nice they send you free sample) and lock washers are worth a try cost you 25 cents
Discussion Starter · #7 ·
mike93eh said:
there are two different kinds of erd threadlocker. there is the red high strength threadlocker and the red permanent threadlocker.
i use the red high strength and locking washers. let it cure for 24 hours.
how does one tll the difference between the high strength and permanent?
1 - 9 of 9 Posts
