1 - 8 of 8 Posts
Hey PBP,
I have just reassembled my bike and had some issues with the throttle cable...
When i compress the spring, the little stone at the end of the wire would come out and would render the throttle (handle) useless, since it isn't pulling anything...
I got lucky putting it in and got it working, but how would i resolve this problem in the future?
Cheers!
GHETTO FABRICATOR
If its the stock carb you are talking about.
There is a c clip and another notched clip that is on the top of the slide. These are in turn pushed down by the spring holding everything together.
I am thinking you are missing the notched clip.
Both are there...
The clip holds the piston needle in place, for adjustment on the low end.
I don't think you should remove the c clip. You can move it up and down is the performance isn't satisfying...
1 - 8 of 8 Posts
