My 5 port 1pc head cag has some mods,6 port windowed piston,lightened piston,,polished piston,blueprinted bottomend,,polished crank bearings,,polished rodend journal,,polished piston pin,,polished crankseal areas,,modded ring grooves,raised and widened exhaust port,,widened transfer port with slight raising,,lightened flywheel,,rocket key,,hp plug wire,,NGK racing plug,,Walbro WT813 carb thats modded,,3" UNI foam airfilter,,composite reeds w/tin reed finger mod,,modded reedplate/modded reedstopper,,modded and lightened clutch,,dual chambered rev pipe exhaust mod 7/68 gearing ..........37.2mph on juiced-up 93 octane mixed with Maxxim 927 juiced-up on 3 ounces of 108 outlaw octane booster and 2 ounces of lead substitute per gallon.........
My Evil Wap cag has a 43cc 2pc 15:1 alky cylinder I super power ported and added a 3rd port to the cylinder aswell as a 5 windowed,,modded ,, lightened and polished piston,,fully blueprinted engine,,full circle crank,,ADA 4 petal reedblock,,Walbro WT813 carb thats modded,,UNI 3" airfilter,,2 shoe adjustable racing clutch,,Homemodded fatty-rev pipe.......Its geared for some serious track racing with a 6/68 gearing but it tops out at 38.7mph now and has some pretty wicked and scarey power enough to pull lower ratio gearing but thats the fun of having so many cags......They can all be geared differently to suit the need for speed at the moment......
My Green Monster Energy X1 has a 2pc headchop with some mods,,2 shoe hp cag modded clutch,lightened flywheel,,rocket key,fatty exhaust,,modded stock carb,ported intake,,boost bottle,homemade velocity stack airfilter and on 12/25 gearing its hitting 43mph
My Black Magic cag has extensive engine work like the 2011 cag but has a 3 port cylinder,,Full Circle Crank,,ADA 4 petal reedblock and modded JetPro exhaust....... 46mph on 7/55 gearing but it is strong as heck in the bottomend..Strong enough to pull 8/55 or even 7/47
My old 5 port 2 pc head cag w/del rep 19mm carb had a stock modded exhaust,,lightened flywheel,,rocket key,,full circle crank,,modded and lightened clutch,,reedplate/reedstopper mods,,composite reeds w/tin finger mod..........49.8mph on 7/47 gearing
My Minitrike of Death has a Techumseh TC300 3hp 2 stroker engine thats modded wickedly enough to push 8hp and get the trike to 50.6mph
My twin engined Mini Harley has twin 43cc engines with some basic mods..On 17/32 gearing its hitting 52.2mph.......After the repowering/remodeling/regearing Im looking to see speeds faster than 60...
My Homemade R/C Buggy that was formerly 35cc and 32mph now has a 1pc headed 49cc that I pulled from the stand-up scooter w/CVT when it went 49mph...After a lil more porting and other mods its propelling the 37lb buggy to 53mph which is just as fast as my 29cc Fuellie engined HPI 5B that has some mods aswell.........LOL
My stand-up scooter has a 49cc piston ported engine with 2pc headchop,,full circle crank modded with longer rod and extensive mods done to the rest of the engine,stock modded carb/intake and boost bottle,,cag 3 shoe hp modded/lightened clutch, and CVT transmission...Its got 18/32 gearing and hits 56mph...Its strong enough to pull a 18/25 gearing to see 60+mph..
My old Blata 2.5 was my fastest pocketbike....70+mph with a 70cc twin carbbed methanol huffing racekart engine til the neck snapped off the frame which ended up with me snapping my neck in 2 places...
Same engine before putting in the Blata 2.5 it was installed in a schwinn stingray bicycle that did faster than 90mph until the spokes couldnt handle the strain collapsing the rear rim/tire.........
I had and have way more bikes and could be typing here for hours but you get the idea..............
