Try changing the sparkplug or richening the lowspeed needle.......today when i went to start my cateye it would run but only if i gave it throttle,now it doesnt idle,ive been trying to mess with my fuel screw to try and make it idle and so far no luck. any suggestions?
The lowspeed needle is a different part that does a different function....The function you most likely need................you could also not have a fuel restriction or enough oil mixed with the gas.......ok because ive had it running just fine for the past 2 days and this just happened today. Ive richened the fuel by a full turn and its no better and it gets really hot.
Check your carb gasket..........It could be damaged and you could have an airleak....well i looked into it and no restrictions,should i rejet?
I put on a velocity stack and thats around when the problem started
trash on the pumper needle,,,,,,the fuel flappers must be totally flat and the diaphragm without any distortion to it.......Checked gasket: torn but not visibly to the seal area but im going to get a new one anyways,messing with the screw wasnt doing any good. i noticed fuel coming out of the intake so i took apart the carb and checked/tested for cracks and found nothing so what could it be?
