Finnally back to the drag bike, after a long winter. Have Walbro HDA 48Ds 19mm pumper carb w/ accell pump. There on Cag 603 manifolds right now. Have 2 of the reed box 4 reed Cag ADA racing manifolds on the way got the last 2, Cam2 has pictures of his two set on Cag, Cag, Cag I believe. These 19mm w/ 15.1mm venturi are so much bigger than the 15.88 x 12.7mm 603s, plus the have an accell pump. The carbs on the new manifolds will sit at an angle so the accell tube is on top of the bore.
