1 - 8 of 8 Posts
hey again all,
I just installed jetpro exhaust and tried starting scooter up and it will try and start but won't start or completely turn over, it has compression and the spark plug has a spark but I just can't seem to start the stupid thing! how can I check if its the keypad without buying new one?
Discussion Starter #2
o yeah, the carb fuel bulb will suck in fuel but won't completely fill up(will fill up over halfway) and makes a squeaky sound
Try some flammable liquid in the cylinder. If it fires off for a second then spray through the carb. If it fires again it’s a fuel delivery issue
Sounds like you need to re-jet or if its a 15mm pumper open the low speed jet on top in the round brass piece and the spring loaded high spring on the side. I would turn both open 1/4 turn then see if it starts. Open the throttle a hair when your starting it.
ok I adjusted the carb and it started, I think it was harder to start because I haven't started it in a year
Very good, glad it worked out for you. Every year after I remove my bikes in storage, I put a little gas down the carb, makes it easier to start. Best bet is to put some gas in and turn it over a few times to get the bearings lubed.
1 - 8 of 8 Posts
