Buy the notch you mean rocket key, offset crank key for 10% advance in timing. Make sure you get the big key for P/Port engine and not the small key for a Cag reed port. Search under 49cc pocket bike parts. I have a 5 port Cag eng. w/ 3 upper ports which leads to a lot of piston wear, cause most of the upper cyld wall is gone. The best is one wide upper port but 2 is ok. The FC crank is good, it won't rev as high a 47cc w/ stock crank, but it has more low end torque a lot more mid to upper power, which means you can gear up for more top speed and still have a decent low end. The crank is much heavier than stock, but it fills up a lot of space inside the cases, so when the piston comes down and the reeds have shut it makes more pressure than stock, which means faster/better fuel flow. You have an hp exhaust a racing exhaust looks like this. All these people BS a lot, X18R Nitro, I have one there is no nitro.
5 1/2 HP, try maybe 3 1/2, 5 to 7 1/2 or more mod with the right mods.
