1 - 2 of 2 Posts
The right lever on my Lucky7 singarm cag which operates the front brake is very loose. It is basically non-functional for braking. Should I loosen the wire catcher, move the wire further down and tighten the wire catcher or can I just adjust the 2 screw by the lever? How does those two screws work?
Thanks,
take the slack outve the wire on the brake setup on the front tire. loosen the bolt that holds the wire, pull slack out and tighten. or just get some new brake levers.
1 - 2 of 2 Posts
