1 - 2 of 2 Posts
hello im n need of help never worked on engine before i have had bike for 10 havent rode ut in luke 6 when i last rode it it worked fine went to start it to teach my son it wouldnt work so disconnected all wires bought new battery took carb out wiped down engine checked spark plug got spark but cant figure out if wire from plug is in good shape and also need ti know exactly how to put carb back together im having brain fart and cant remember exactly haveing prob putting throttle cable back on too help please
To attach the cable you need the pusher spring and in the trunion theres a recessed end that the cable end fits into,,to get it in there youre gonna have to rotate the throttle wide open...........
remove the gastank and clean it out
make sure the fuellines are on right,,,black line goes on the larger ribbed nipple on the carb and the clear line goes on the smaller smooth nipple
make a fresh mix of 93 octane mixed to 50:1
sparkplug is BPM6a gapped to .030"
1 - 2 of 2 Posts
