1 - 3 of 3 Posts
I just bought my walbro carb and before pbp was restarted someone said they had a problem where the bike started once and didnt start again. Does anyone think that this would happen to me because i will be really mad if it does.
Why not wait and see what happens? Anything can be fixed. There are a TON of Cag folks here to help you if you need it.
Breathe..................Breathe...............;)
That was me. i out it on perfectly following the directions. put the initial settings where they were supposed to be and it just kept flooding out the motor. it only started one time after sitting in my van for a few hours in 95 degree heat. i guess the heat evaporated all the gas in the motor, but it still took like ten tries before it started. i had to gas it for it to start. then i adjusted the idle so it would idle. revved it a few times let it idle for about ten min. (i couldn't ride it cause i was at work). i put it up then it never started again.
I'm pretty sure the carb was jacked up so i ordered another and i should get it today.
1 - 3 of 3 Posts
