Thanks to Jaloos, and the manifold he made for his W/C engine. I got an alum Cag hp manifold and measured it, to find if I mod the manifold holes & alittle grinding inside the manifold for more space to feed the 4 reeds, it will bolt up. Its going to be mounted sideways and to the right and so is the WT603 Walbro Rep carb. Since the carb has no float bowl, and has a fuel pump it should not matter that much. The plus is the H & L adjustments and idle screw will be on top of the carb.
Has anyone tried this before??
I thought some of you my might enjoy my Mountain Engine Stand Bench, w/ the gas tank nailed to a redwood tree & my return tank is a plastic lunch meat container, w/ a gas line thru a small hole, but it works Great!!
