Im wanting to do a motor swap to a lifan 140cc on my x18.
The kit i am buying comes with:
Lifan 140cc motor
26mm Mikuni carb
40 mm air filter
cnc oil cooler set with oil lines
kick start shift lever
clutch cable
clutch lever perch
engine cover
engine wiring harness
24mm intake manifold
seal gasket and nessisary nuts and bolts
ignition coil
cdi box
and a wiring diagram
So what do i need to get after all that?
can i use my x18 throttle controll and cable?
and will I be able to use my stock exaust?
Please help me out
Lifan 140cc motor
26mm Mikuni carb
40 mm air filter
clutch cable
clutch lever perch
engine cover
ignition coil
cdi box
Please help me out
